can I use my sram c...
[Closed] can I use my sram crank if I change to 1x11?
[#7836482]
I currently have a SRAM 0x double.
can I use this chainset, change the ring for a sram 11 speed and change the rear mech and chain?
would this work?
Posted : 19/05/2016 8:11 am
I'm using a 10sp X9 double with mine, it's all the same really. Some chain line potential issues with a double but not much? Is it a removable spider? If so go direct mount and it will line up right.
Posted : 19/05/2016 8:17 am
not sure about the spider. all I know is its the 0X with carbon arms. direct mount...will look into that.
need to check I can get a 11spd ring with 104
Posted : 19/05/2016 8:23 am
also will XT cassette work fine with sram chainring and chain?
Posted : 19/05/2016 8:29 am
Mine is a mix of XT shifter, mech and cassette with sram chain and cranks. Works fine. If it's a X0 crank the whole spider should come off, there's 3 bolts on the back. You can then fit a direct mount chain ring
Posted : 19/05/2016 8:54 am
You dont need a specific 11sp ring, any 104bcd NW will work
Posted : 19/05/2016 8:58 am
so if I can fit Direct mount chainring. I can install an 1x11 setup that works perfectly (chainline wise) like a full 1x11 groupset?
can I mix a XT 11spd cassette? (they are cheaper than sram 11spd cassette)
Posted : 19/05/2016 9:00 am
Yes, though I'd go sram cassette lighter bigger range and now that much more for gx.
Posted : 19/05/2016 9:03 am
this is the crank
Posted : 19/05/2016 9:10 am
I have the same cranks. I use a direct mount oval ring, the rest of the drive train is sram GX 11 speed and it works perfectly.
Posted : 19/05/2016 9:16 am
buzzing! thanks guys
Posted : 19/05/2016 9:18 am
looks like the direct mount sram ring is only 28t (I ideally I was looking for 34)
Posted : 19/05/2016 12:38 pm
found 34 t ones but more expensive
does it matter if I have BB30
Posted : 19/05/2016 12:42 pm
Compatibility chart here helps?
https://goo.gl/bV1Qip
Posted : 19/05/2016 1:00 pm
hm, not sure If I have a long spindle or short spindle bb30 ?
also will an 11spd cassette be cool on a 10spd hub?
Posted : 20/05/2016 1:40 pm
