as above. looking at 185/160 combo
Posted : 18/09/2010 10:44 am
I have used them with Juicy 3 ,5 and carbon. The problem is the rivet bolts of the floating rotor catches the caliper as they spin so they click. You can grind off the leading edge of your caliper[it cathes the part that you put the bolt through to the mount] to avoid this if you wish.
I would assume elixirs are the same but not certain.
Posted : 18/09/2010 11:16 am
cheers
Posted : 18/09/2010 11:23 am
