Thinking of buying a 2nd hand Fox fork with a 15mm axle. Currently my wheels use qr. Will there be compatibility issues?
Posted : 17/06/2015 3:56 pm
Yes, you will have issues. A 15mm axle will not fit in a 9mm hole.
Depending on the wheels you may find adapters, if they're superstar switch or some hope for example.
Posted : 17/06/2015 3:58 pm
What hub do you have? Only way to know for sure
Posted : 17/06/2015 4:45 pm
mine went the other way around ... 15mm fork, 15mm wheel then got
some carbon rigid forks that were 9mm - couple of mavic adapters
sorted me.
you may find that you'll have to change the axle or worse the hub !
Posted : 17/06/2015 5:32 pm
Some hubs (e.g. Hope) can be swapped around 9mm, 15mm or 20mm.
Posted : 17/06/2015 5:41 pm
