200mm and 160mm discs it is.
-or will i be doomed !
Posted : 02/10/2009 1:47 pm
probably. so long as you have enough disc area for your pad you'll be good to go.
if you're looking to get discs to replace worn ones try mtb-direct.com. cheap as chips.
Posted : 02/10/2009 3:17 pm
I see no reason why you cannot mix rotors and systems form different makes, only exception is vented rotors!
Posted : 02/10/2009 3:26 pm
I dont think any of the white painted Formulas work on any brake disc at all, it was a terrible manufacturing error, but as luck would have it I have a museum for such engineering faux Pax, send them to me and they will get pride of place.
Posted : 02/10/2009 3:31 pm
Yes works fine
Posted : 02/10/2009 3:50 pm
