20mm of extra travel won't stop your eyeballs being shaken out.
is it worth asking if your suspension is correctly set up for you?
150mm travel both ends needed as a bare minimum! 😉
I've just gone from a set of 140 Float RL from 2010 to a set of 2nd hand 2012 Rev's with a QR15 on my 2010 Heckler (1 1/8 head tube). The change to the geometry and handling is negligible but the extra stiffness is very noticeable, especially when I was playing around with pressures etc on a rocky descent at speed. They just feel more substantial than the Floats - I don't think I was riding any faster than normal but I certainly felt more in control.
That's good info thanks
Bobby that is a perfectly reasonable question. They're the Talas R version so they don't have much in the way of adjustment but I tend not to have the rebound too fast and run them at about 30% sag. I'm 11 stone and I run about 75-80psi. I find if I put less air in I get brake dive...
Does compression damping fix brake dive?
Maybe I'll just man up and live with the weight penalty, or just put a rev on like 1000 other people have already mentioned. Almost seems too easy...
Haha Rob that's awesome!
Be honest though, that's not the first time you've ridden that section is it?
I do need to get better...
Oh no that's definitely not me I mince down like a good un.
On a 140mm hardtail usually though...
To be fair, he makes that look very easy. It's quite steep in places, especially that left hander at the top where it's easy to sh@t ones self at the sight of what's in front of you (a big drop). I love it up there though! I can ride from my house to redmires to there, to foxhouse and back to mine in about 23 mile round trip and this is the only bit that gives me problems.
Loving the peak district.
There is some cheeky stuff near there that makes stanage plantation look like Sherwood pines. Time to explore a bit more! 😀
Sounds like you are loving the peaks riding, great isnt it! Hard to say exactly what might be causing you to feel so unbalanced with actually looking at your full bike set up and body position but it might be worth having good shop or coach give you some set up pointers. Just to avoid buying forks for the reason that they match your colour scheme. Hope this does not come across as condescending.
I am sure there is, i've found the Blacka Moor trail after reading "Dark Peak mountain biking" but it's verrrry muddy in winter, the jeep path is almost impassable in places. I made the mistake of leaving my bike unwashed for a couple of months after riding that and went back to it to find the bottom bracket completely ceased up!
It's difficult for me to explore as much as i'd like because i work away from home a lot so don't get much time so when i do go out i tend to stick to places i know, but if you've got any pointers or fancy getting out for a ride some time just drop me an email.
No not at all, i actually like the way my bike's set up it's just i crave a bit more cush on sections like this and others where i just feel like ploughing through some of the boulder gardens! I know people say a 36 is great fun on a heckler but i just don't fancy the extra weight penalty.
At the end of the day, i should have bought the Revelation XX that has just gone for under 200 on the classifieds - i would have lost a few grams and gained more travel and a bolt through axle but alas, i am a plum 🙂
The difference between QR and 15 or 20mm is pretty noticable... But it's nothing like the difference between a 32 and a Rev! Fox basically just took their XC forks and kept stretching them over the years, they're extremely bendy. So, if that doesn't bother you just now, don't worry about flex- you have probably the worst performing modern fork in terms of stiffness, and you don't mind, so fahgeddabadit.
