Can I nitromors...
[Closed] Can I nitromors...
[#8438084]
A plasticoat finish on a ti spring?
None in stock of the type Im after....theres one on ebay in a colour that makes my eyes bleed...
Will it look like a standard ti spring after - or do they apply a finish to the silver ones?
Posted : 03/04/2017 12:15 pm
better to burn it off?
Posted : 03/04/2017 12:33 pm
Modern nitromors is rubbish, they took out all the evil stuff. Hot air gun might do it better? But a spring's going to be a pain in the arse to clean stuff off. I don't know what the heat tolerances will be before you affect the spring but I'd assume they'll be above the point where a plastic coating melts.
Posted : 03/04/2017 12:37 pm
Not sure I feel like burning plastic....Ill just get a Valt spring and the Fox adapter.
Cheers chaps.
Posted : 03/04/2017 12:47 pm
paint it black with a rattle can?
Posted : 03/04/2017 1:21 pm
Enduuuuuuro!!
Posted : 03/04/2017 1:33 pm
These days you could happily Nitromors your nuts.
Posted : 03/04/2017 2:50 pm
Nitromoors won't touch it. Paramose is your friend, but it has a big skull and crossbones sticker on the side of the tin....
Posted : 03/04/2017 6:16 pm
^ just for pirate use then?
Posted : 03/04/2017 6:26 pm
If it's really Ti, i'd suggest not. Ti is funny stuff, any chromium or aggressive things like bleach in contact with it can cause early life failure!
Posted : 03/04/2017 7:01 pm
stevied - Member
Posted : 03/04/2017 7:31 pm
Could you not cut a line down the outside edge of the coils and then 'unwrap' the plastic?
Posted : 03/04/2017 9:06 pm
"better to burn it off? "
burning springs= non springy springs.
Posted : 03/04/2017 9:25 pm
I went full enduro though and bought an SLS spring - couldn't be bothered faffing around with Cane Creek VALT adapters/ordering them from Germany...I'm impantient.
Cheers anyway chaps.
Posted : 03/04/2017 9:38 pm
