Can i modify my nuk...
[Closed] Can i modify my nukeproof 44mm 1"1/8 head set to accomodate tapered forks?
[#4530101]
i have some 1"1/8 steerer forks at the moment but want to change to 1.5" tapered steerer fork on my nukeproof mega frame. anyone know if i can modify my Nukeproof warhead headset without having to press the cups out? i.e just change the bottom bearing and crown race?
Posted : 05/11/2012 10:10 pm
Internal or external bottom cup currently?
I'm not sure, doubt it, but would recommend the Hope mix and match lower cup only, about £25 from Merlin.
Posted : 05/11/2012 10:22 pm
bottom cup is external and top cup is internal currently
Posted : 05/11/2012 10:24 pm
Are your current cups internal or external to your head tube?
you will need the lower cup to look like the one in the link below or it will not work.
http://www.chainreactioncycles.com/Models.aspx?ModelID=55502
Posted : 05/11/2012 10:27 pm
i have the 44IESS, im guessing the cups are the same but with a different lower bearing and crown race
Posted : 05/11/2012 10:31 pm
you might just need a different crown race
Posted : 05/11/2012 10:32 pm
mind you lookin at that link rusty there is a chamfer on the lower cup so its possibly a larger diameter cup than the headset for a straight 1" 1/8 steerer
Posted : 05/11/2012 10:35 pm
If external is your current crown race a large plate like piece?
If so then all you should need to is replace the crown race with a 1.5 race. Contact CRC and see if you can buy the correct crown race.
Can you post a pic of your current setup? it'll make life alot easier!
Posted : 05/11/2012 10:38 pm
ok thanks for the feedback, i'll have a search.. have searched for nukeproof headset spares before but not had much luck
Posted : 05/11/2012 10:41 pm
