Can I change travel on my 2015 revelations.
Solo Air RC3 120mm
If so, what do I need and how do I do it?
Loads of YouTube videos, but they tend to be for newer forks.
Looking to go to 150mm. Might be pushing it?
pretty sure this will do it
Rock Shox Revelation Solo Air Shaft 150 mm Change Travel https://amzn.eu/d/4W7Y9OL
If you put the fork serial no in the Rockshox Trailhead app it usually tells you what the part numbers are.
Perfect, cheers.
Looks like I need
11.4018.022.000 FORK SPRING SOLO AIR SHAFT - 150MM-26"/27.5"/29" (INCLUDES AIR SHAFT, PISTON & SEAL) - REVELATION 32MM-A1-A4 (2010-2017)
The amazon one linked doesn't specify the part no above, but looks like it may be it
