RS8
considerably less than if they were squaretaper.
probably 40-50 quid id have thought since complete with rings and in good nick
isis is bollocks - probably 50-70 quid if squaretaper as folks go mad for them like audis
With the hollowed out arms they look like RS8's.
Edit what he said ^^
RS7s are scooped out too.
RS7's used to have them myself 🙂
I have two pairs of RS7s and these look very very similar, but Ive never seen RS8s (discontinued) so cant be 100% sure as I dont think RS8s looked dramatically different.
they didnt tbh - difference was only about 25 grams or so - slightly narrower profile and the pedal area was longer - tbh these could be rs7 or 8 but the perspective of the photo makes the pedal "flat" look longer than the rs7s i had
So RS7 look more likely than RS8s, are we agreed on around £50ish. If so I'll fire them on the classifeds.
No need - I'll take em.
£50 about right for ISIS.
Sq Taper are around £70ish.
Less without spider as they cost a bit to replace.
BTW - off out direct from work but will mail you tonight mcoonter to sort payment 😉
DBW theyve got your name on them.
Lights blue paper and walks rapidly away... I think Isis can be ok with the right BB.
Thought rs8 had the 3 bolt spider only...they look like rs7 to me...great cranks.
My rs7s had the threebolt spider , was an option on both chainsets , rs8s definantly came out with a 5 bolt 94cd spider( spider web design) i remember lazy boy lazenby using them.
rs7 and rs8 were for most purpose the same, same spiders same general shape, 3 bolt, 4 bolt, 5 road, road compact road normal atb standard, etc, etc, etc.
DBW YGM
