Campagnolo conundru...
[Closed] Campagnolo conundrums - help needed...
 barn
[#6821152]
Question 1:
Where to find replacement chainrings for compact Veloce 10 spd (ultratorque cranks circa 2006)?
LBS have MOV of £150 so can't easily get from Chicken.
Question 2:
Veloce 10 spd levers with Shimano 9 spd block, mech and chain with a Jtek Shiftmate. Question is will a Shimano front mech (double 9 spd Sora) work with Campag left lever?
Thanks.
Posted : 29/01/2015 9:17 pm
 aP
I have TA chainrings on my 11spd road bike and 10spd cx bike - both Campag Ultra Torque compact chainsets.
As long as you don't have the painful Ergolevers with indexed front shifter then I can't see why it shouldn't work with a different mech.
Posted : 29/01/2015 9:21 pm
1. any 110 bcd chainring. In the past I've actually bought complete chainsets and sold the cranks as it was cheaper than buying rings
2. Yes. I've done it with loads of combinations. All fine.
Posted : 29/01/2015 9:55 pm
Campagnolo condoms is what I first read 😯
Posted : 29/01/2015 9:56 pm
Just a point, with your ergos and mech, you can use a 10s shimano cassette via the hubbub method.
http://forum.ctc.org.uk/viewtopic.php?t=20064&start=0
Posted : 29/01/2015 9:58 pm
 barn
Thanks Nemesis.
Question 1 & 2 sorted - genius.
So I could re-route mech cable (a la Sheldon), ditch Shiftmate and use a 10p Shim block?
You just saved me £40!
Posted : 29/01/2015 10:27 pm
Yep. You would need a 10 speed chain and cassette though.
Posted : 29/01/2015 10:29 pm
 dobo
fwiw 8 speed cassette works perfectly with campag veloce shifters with no mod needed and no shift mate. you can use any 9 speed mech or a road mech for that matter.
its what i use on the cx.
tried the hubub method but didnt work well for me with my mech on 9 speed.
sram do good cheap 8 speed cassette.
Posted : 30/01/2015 12:19 am
You can't use "any 110BCD chainring" as Campag have one bolt offset at 108 mm so as to get the rings correctly timed relative to one another ... TA do a compatible ring or we probably have stock of the relevant outer ring. If you'd like, please PM.
FD will shift better with Campag 9/10 compatible & if it's set right, you'll be able to use all 10 sprockets from the big ring without trimming - but the Shimano units aren't too clunky with 10s and only occasionally throw off to the inside (on the 9s units the cage is a tad too wide ...)
HTH
Graeme
Velotech Cycling Ltd
Campagnolo main UK SC
Posted : 30/01/2015 1:34 am
Might find some suitable chainrings here for that era that are campag specific:
http://www.ribblecycles.co.uk/pp/road-track-bike/chainrings-road/chri
Replacing an outer chainring on my centaur powertorque 10sp, and these are pretty cheap. Otherwise it's new chainset and selling the cranks as nemesis says above...
Posted : 30/01/2015 10:03 am
I can't see that 🙁 - how does one bolt location affect anything (assuming there are more than 2 in total) ?
Oh, and what do they mean by timing ?
Posted : 30/01/2015 10:14 am
One of the 5 bolts is slightly offset so the chainring can only be fitted in 1 position (and other rings won't fit). This position is optimal for campag rings that have been machined in such a way as to optimise the shifting. I think that's what gfkvelo meant?
Posted : 30/01/2015 10:47 am
Oh yeah 😳
As he says, the chainring bolt behind the crank arm is a different bcd so for Campag you need a campag specific chainring
Should really have remembered that as I have the same chainset on one of my bikes...
Posted : 30/01/2015 12:11 pm
