Campag-Shimano mixe...
[Closed] Campag-Shimano mixes
[#3852198]
I'm faffing around with my daughter's cross bike, which has Campag 9sp shifters and small block (max 24T, I think)
She would like a lower gearing, but we only have Shimano blocks on other wheels. Will the Campag shifters work ok with the Shimano sprockets?
Is there anything I should be aware of when swapping various bits over?
Posted : 09/04/2012 1:33 pm
 aP
Why don't you just buy her a 9 spd Campag block with a lower gear? They're about £32 at Parkers.
Posted : 09/04/2012 1:37 pm
The spacing is close enough for it to work OK with shimano 9s but of course there may be wear/meshing issues, also chain length and rear mech-large cog issues.
Posted : 09/04/2012 1:39 pm
...campag blocks won't fit Shimano wheels.
Posted : 09/04/2012 1:49 pm
I assumed he knew that!
Posted : 09/04/2012 1:50 pm
Thanks so far.
Yes, we have a Campy hubbed wheel with small block, and a Shimano-hubbed wheel with 12-32 or so. I need to alter a the chainline too. Thanks for the tip about Parkers
Posted : 09/04/2012 2:04 pm
I have used Shimano wheels and cassettes with a full 9 speed campag and alas I am afraid to report it worked better than the full campag system
Posted : 09/04/2012 2:20 pm
 kilo
Have you considered putting a smaller chainwheel on the front, might be cheaper
Posted : 09/04/2012 3:10 pm
