Looking to replace my campag chainset to a compact type. It's an old 8sp type using a taper b'bracket. I've seen on fleabay campag compact chainsets that say 10sp. Presume these won't work with my current 8sp setup?
Not sure they did an 8 speed specific chainset in compact, pretty sure a 9 speed will be fine, assuming they did a square taper 9 speed version. Campag and retrofit aren't two words that go well together.
Also Campag 8 speed is getting hard to get.
Edit I tried an 8 speed over a 10 speed chainset and it was very draggy!
[url= http://www.parker-international.co.uk/12665/Campagnolo-Champ-9-Triple-Chainset.html ]THIS[/url] might be as near as you can get.
I've got a 9 speed sq taper compact 50 / 34 either 175 or 170 works fine with 8 speed, £40 posted Veloce or mirage, silver with stick on logo, can do pics if interested
Martin
Martinb
yes please. Could you send me a pic please?
You could look out for an old RSX chainset - my islabikes cx built for me in 96 was built up with 8spd Mirage with a 46/36 RSX.
It'll be absolutely fine, you could fit an 11 speed Super Record chainset if you wanted.
Rings are totally reverse compatible.
