Campag 8 spd questi...
[Closed] Campag 8 spd question
[#2936571]
Got a veloce 8 speed setup on my old commuter - The freehub pawls are on their way out - I might be able to bodge it but throwing out a question to the STW massive:
I have a shimano rear wheel going spare - could I fit a shimano 8 spd cassette to it and run it on the campag 8 speed group set? If not what are my options as I don't want to change the groups et as the bike is not worth it?]
could I use an ambrosio on teh 8,9,10 speed compat shimano freehub body?
Posted : 12/07/2011 11:23 am
Sheldon Brown is your friend
http://www.sheldonbrown.com/cribsheet-spacing.html
They are prob close enough to get away with it .
CTC would suggest alternating the cable clamp route http://forum.ctc.org.uk/viewtopic.php?f=5&t=28705&p=233480&hilit=shiftmate%3F
one of these maybe if needed http://jtekengineering.com/shiftmate.htm
or put a 7 sp shimano cassette on with a spacer as thats still 5mm spacing (obv you lose a gear tho)
Posted : 12/07/2011 12:33 pm
cheers canny - yeah was looking at the jtec shift mate - hmm the 7mm cassette with 5mm spacer would seem a good / cheaper option though - many thanks!
Posted : 12/07/2011 12:38 pm
Just got a very cheap 7 speed cassette and spacer - Will give me time to service the freehub body on the campag wheel properly and see if it is def knackered or source some parts 🙂
Posted : 12/07/2011 12:59 pm
 dobo
check out this CTC article that shows different options that might work for you.
http://www.ctc.org.uk/desktopdefault.aspx?tabid=3946#Hubbub
not sure if this helps exactly but on my CX i run veloce 10 speed shifters and a sram 8 speed cassette along with any 9 speed rear mech and it will shift just fine (which the article above confirms so should be fairly reliable)
Posted : 12/07/2011 9:06 pm
All the above fine.
However the spacing difference is 0.3mm. set the mech up correct for say 3, 4,5, and its bugger all. Just bung a 8 speed Shimano casstte ona Shimano hub. Nice and easy to find. A touch of wear in the mech rollers and it will be fine. I have a set of Record 8 spee shifters for yesr, since Campag went 9 speed. Almost alwsy used them on Shimano hubs and cassettes. Rumour has it that it will work while everything is new but I find a ouch of wear eases things. excessive tweaking is also a danger. I play with my bike way to often for that to become a issue. Worth a try first.
Ambrosio make Campag splined, Shimano spaced 10 speed cassettes. Maybe there's a 8 speeder.I think Miche do. Try retrobike.com as you are very much in that territory.
Perhap I should sell my 8 speed hub and barely used cassette. Interested?
Posted : 12/07/2011 10:26 pm
Cheers Matt - I just got a cheap 7 speed cassette and spacer and it will be a direct swap just need to set the upper limit screw - cheers for the offer - I also got a very good link from Highpath:
http://www.highpath.net/highpath/cycles/info/rear.html
Posted : 13/07/2011 7:51 am
7 Speed spot on - Using shimano wheel - indexes fine 🙂 £14 to do the job - sorted 🙂 Happy cycle to work this morning 🙂 Cheers Guys
Posted : 14/07/2011 7:41 am
😛 Works a treat doesn't it. Now just wait for the Ergos to poop their pants. Still they're totally rebuildable, but it's a frustrating process.
Posted : 14/07/2011 7:58 am
