Camelbak & Othe...
[Closed] Camelbak & Other Bladders
[#7343556]
My 3 litre Cambelbak started leaking from the twist-lock cap yesterday. I was wondering if it is a common problem with the current Camelbak, and if there is a cheap fix for it.
I notice that an identical replacement will cost about £25 but there are some much cheaper options available. What do Singletrackers think of the alternative brands of bladder available?
Posted : 21/09/2015 5:11 pm
I love my Platypus - small filling hole but never got the black grunge and I just rinse it out after use. I use a camelbak tube and bite valve with it.
Posted : 21/09/2015 6:05 pm
 m360
Take it back to the retailer you purchased it from, Camelbak come with a lifetime guarantee and are pretty good about it (either send you a new seal or a new bladder).
Posted : 21/09/2015 7:19 pm
I just got a 2l Osprey bladder for about £20 from Wiggle. Impressed so far - better bite valve and water flow, easier to open than the Camelbak, little touches like a carrying handle and a magnetic clip to keep the bite valve in place.
Posted : 21/09/2015 7:37 pm
There are much better bladder designs than Camelback, my Evoc is simpler, lighter and allows the entire thing to be pushed inside out to clean.
Posted : 21/09/2015 8:01 pm
I was going to buy a replacement bladder the other day for £25 then I saw this with a 2 litre bladder included for £30!
http://www.chainreactioncycles.com/evoc-cc-backpack-3l-inc-2l-bladder/rp-prod131646
Posted : 21/09/2015 8:22 pm
Anyone had any luck with the cheap eBay bladders?
http://www.ebay.co.uk/itm/200782988512
Posted : 21/09/2015 9:41 pm
Osprey are the badger's gnadgers.
Posted : 21/09/2015 9:44 pm
Check the large rubber o-ring thingy around the cap is not twisted on itself...that can cause a leak. Otherwise, as mentioned, bladders have a lifetime warranty.
Posted : 21/09/2015 10:19 pm
Has any one had any joy with replacing a Camelbak bladder, is it like for like and will I need to produce a receipt as mine has passed the point of no return with fungal residue I just can't get shut of it.
Posted : 21/09/2015 10:30 pm
squoglybob - Member
As the black hook/clip thingy has snapped off, so it currently slumps to the bottom of the back pack.
Defo not got a receipt as it must be getting on for 5 years old and tbh, I'm not even sure where I bought it, prob CRC or UKbike store
Posted : 22/09/2015 12:53 am
Another vote for platypus here - they are significantly better than camelback IMO.
Posted : 22/09/2015 2:28 am
+1 for Osprey. Well designed with the rigid back, handle and wa-ay easier to open and close than the Camelbak. Plus extra points for the magnetic hose jobbie...
Posted : 22/09/2015 3:07 am
