Camelback cleaning ...
[Closed] Camelback cleaning brush isn't long enough. disasspointing for £8.99!
[#1013340]
I thought the brushes seemed a bit expensive but then having a long thin brush to clean out the tube sounded like a good idea. But is isn't long enough to reach all the way down the tube.
I don't think the tube is designed to come off at the bladder end so I can clean from each end. It seems very reluctant to come off anyway.
Posted : 04/11/2009 7:57 pm
In all the years i have used camelbacks i have never cleaned the bladder!
Rinse it out when done then stick it in the freezer, job done 🙂
Posted : 04/11/2009 8:04 pm
It does come off, at least mine does.
Posted : 04/11/2009 8:07 pm
My old one comes off.
Posted : 04/11/2009 8:08 pm
si_progressivebikes - Member
POSTED 6 MINUTES AGO # REPORT-POST
+1
Posted : 04/11/2009 8:10 pm
 tang
mine came off and went on again.
Posted : 04/11/2009 8:15 pm
It comes off no bother, otherwise you wouldn't be able to get a replacement if for some reason it gets effed.
Posted : 04/11/2009 8:17 pm
you need to pull it harder.
fnar fnar.
Posted : 04/11/2009 8:18 pm
Run a bit of hot water on the tube first, and it should come off more easily.
Posted : 04/11/2009 8:20 pm
Or save yourself some £££s and use an unbent coathanger with a little loop bent in the end and a piece of towelling material. Works just fine, and plenty long enough 🙂
Posted : 04/11/2009 9:44 pm
I use Milton sterilising fluid . . . about twice a year when the mould looks like it moving!
Posted : 04/11/2009 9:46 pm
freezer...it's kool!
Posted : 04/11/2009 9:54 pm
Mine wasn't long enough for the tube at its original length, but then the tube was incredibly long... Once I cut it down to a more sensible size, the brush was long enough.
Posted : 04/11/2009 11:27 pm
I had the same problem and combined the brush with ajantom's solution and extended the brush using some sort of stiff wire I had kicking about.
ISTR reading that next years brushes are longer but you have to wonder how hard it would have been to test the original ones.
Posted : 04/11/2009 11:38 pm
ahhh.... it does come off, I just needed to be a bit more force full with it. I like the freezer idea though.
Posted : 05/11/2009 12:03 am
Simple solution, get some parcel string, thread it through, tie a knot big enough to require a bit of pulling and then pull it through the tube.
Repeat until clear. £1 simples!
Posted : 05/11/2009 8:44 am
milton
Posted : 05/11/2009 9:28 am
"stick it in the freezer"
I had the camelbak pipe cleaner brush thing, all was well until the head snapped off in the mid-point of the tube 👿
Managed to get it out by some manipulation of the tube but was about 30 mins of my life wasted 😆
(to get the hose off from the bladder end, put the kettle on, bring to the boil and then hold that part of the hose in the steam for a couple of seconds, comes off easily then).
Posted : 05/11/2009 9:36 am
Mine very rarely needs cleaning as I only use tap water in it. (If I'm camping and use bottled water the bladder goes slimy after a few days due to lack of chlorine in the water)
I use a gear cable, wrap a bit of kitchen towel around the nipple then pull it through. Thats a deep clean though once every six months or so, normally combine with a soak in milton fluid.
