Calling suspension ...
[Closed] Calling suspension experts
[#4944231]
Hellooo oh great and wise!
I have a set of 130mm 26" rev's and a set of 100mm 29" reba's, the rebas have some stanchion wear and the rev's are fine, so will the rev' stanchions fit the reba's? Is it a straight swap or a no go?
Ta
Posted : 09/03/2013 7:36 pm
Stanchions likely different length.
Posted : 09/03/2013 7:43 pm
dead easy to do as long as neither or both have the power bulge. (the don't mix n match very well) , however the offset is different between 26" and 29" forks so you end up with a reba 29er with a 38mm offset which will feel a bit slow unless it's one of the original reba 29ers in which case you'll already be used to it.
Posted : 09/03/2013 7:46 pm
having made a few 29er franken forks out of bits of Revs and reba 29er lowers, the stanchions are the same length.
Posted : 09/03/2013 7:47 pm
oh really... worth knowing... #strokes evil chin#
Suppose it means manufacturing less different parts etc.
Posted : 09/03/2013 7:53 pm
Thanks, neither have the bulge and The rebas are the originals, so should be a straight swap then?
Posted : 09/03/2013 7:59 pm
yep about 30 minutes work. if the revs are u-turn you can have ace adjustable 29er forks. 😀
Posted : 09/03/2013 8:54 pm
