Cable/Hose Guide He...
[Closed] Cable/Hose Guide Help
[#3049434]
The cable guides on the top tube of my '08 ASR are 'open' to allow a full run of cable outer through however, especially when it's wet & mucky, the outers get worn through from sliding through the guides as the suspension moves. There do not appear to be any rough edges in there and it's the only thing about the bike that annoys me.
Can you get inserts to turn them into cable stops? A quick interweb search seems to suggest there is something available for older Cannondales but it's unclear whether these are bike specific or not.
Any other suggestions?
Posted : 15/08/2011 9:00 am
Can you not just use a cable tie?
Posted : 15/08/2011 9:06 am
 SamB
Wrap a layer or two of electrical tape round the outers where they're rubbing?
Posted : 15/08/2011 9:47 am
Sam - I'm doing the tape thing, it's just a pain having to re-do it all the time.
Stoner - I don't think they'll work as it's a 5mm outer that's moving/wearing.
Not sure what a cable tie would achieve :-/
Posted : 15/08/2011 10:49 am
Use enough tape to jam the cable in tight? Some of that self-amalgamating tape might work better.
Posted : 15/08/2011 11:07 am
Hmmm, maybe a cable tie each side of the guide would do that too.
Posted : 15/08/2011 11:10 am
