Cable stuck in GRX ...
Cable stuck in GRX shifter
[#12526584]
My shifter has stopped working, and I'm trying to get the cable out so I can replace it. When I click up or down the tension on the cable doesn't change.
I've taken off the little panel on the inside side of the shifter, and as far as I can see the cable is sitting in the groove in the little reel thing. But I can't see the head on the outside. I'm trying to push it out the way it went in but it won't budge whether I push or pull it.
Anyone had this, and if so what did you do to sort it out?
Posted : 03/09/2022 4:52 pm
Frayed cable jamming is the most common (the fail annoying close the head on modern Shimano road shifters)
You can remove the bottom cover to improve access, then normally use a seal pick to tease out the remains.
(part 7 is the cover I would suggest removing to see more)
https://si.shimano.com/en/ev/ST-RX600-4582
https://si.shimano.com/en/ev/ST-RX810-4593
Posted : 03/09/2022 5:10 pm
