Cable routing
[Closed] Cable routing
[#971001]
I had an older Deore rear mech which gradually died. I've swapped to SLX rear but I'm not too happy with the cable route and the shifting.
Should I zip tie a continuious outer from shifter to mech and ignore the cable routing?
It's a Epic and the cables come from the chainstay and almost doubles back on itself. I'd prefer a seat stay option to make the routing cleaner would this work?
Ta.
Posted : 21/10/2009 11:20 am
Yes it should work, just put some tape on there to protect the cable rubbing away at your alu frame
Posted : 21/10/2009 11:22 am
 Olly
you may be able to run it down the inside of the swingarm, i can on my trance (but havent)
Posted : 21/10/2009 1:34 pm
