cable hose guides -...
[Closed] cable hose guides - Help!!
[#1580346]
Trying to find these but to no avail - I want to install them on the cable supports on my Five to stop the frame wearing away as the front as the cable move with steering?
This image is from the jagwire USA site 🙁
Posted : 06/05/2010 4:03 pm
In the UK? Think I might be bodging it with some electrical cable rubber grommets 🙂
Posted : 06/05/2010 4:17 pm
Pass, Jagwire is distributed by Moore Large if that is any help. Your LBS may therefore be able to order them however if you want two and they come in a pack of 50 then they may not.
Posted : 06/05/2010 4:19 pm
found one in the garage if you want it (mail in profile)
the little plastic grommets you get with wheels are the same size just shorter, might be worth a try as well
Posted : 06/05/2010 4:42 pm
Cheers guys. khani I need two and the right size ideally - what are "little plastic grommets you get with wheels" ? do you mean the presta/shraeder convertors? I think they will be too small 🙁
Although this might work?
Ahh I got some tap washers at home - I might have a look there 🙂
Posted : 06/05/2010 4:44 pm
they convert the valve hole to swap between presta and shreader you normaly get them with mavic rims, looking at them now and they are the same diameter and bore as the whatsitcalled in your pic just not as long
Posted : 06/05/2010 4:48 pm
I think I'll have a look in my junk / DIY boxes I think I can bodge sommink 🙂 Thanks for the help though 🙂
Posted : 06/05/2010 4:49 pm
Ison Distribution, maybe ?
Posted : 06/05/2010 9:29 pm
No 🙁 I thought about a fine point marker outer - cut to length, small filled area center so the zip tie can grip - Done 🙂
Posted : 06/05/2010 9:38 pm
