Rounded out one of the cable guide bolts on my big top (idiot I know!) and need a new one, don't know what size it is though, anyone know?
Looks the same as the one for the ASR-7 replacement i found on silverfish
[url= http://www.silverfish-uk.com/ProductDetail/0/11175/Cable-Guide-Kit-ASR-7 ][/url]
Damned if I'm paying £30 for it though.
put a ruler across the end of the thread, round up to the nearest mm, then measure the threaded part's length. then you'll end up with the necessary dimensions. for instance a screw with a 3mm diameter thread by 10mm long thread, of the type in the link you ( nearly! ) posted would be an M3x10 Counter Sunk.
HTH.
I had the same problem. They are M4 x 15mm Countersunk (Allen head) stainless steel screw.
I got some from here [url= http://www.ebay.co.uk/itm/251615113426?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT ]link[/url]
They fitted perfectly, hope this helps you and anyone who searchs for this
