Cable ferrule
[Closed] Cable ferrule
[#8055699]
Any genius ideas for a quick short term ferrule bodge?? Household items?? Ta
Posted : 14/09/2016 7:27 pm
 Olly
Not bought one in years. Super glue mine
Posted : 14/09/2016 8:55 pm
Wish I'd read that sooner, ended up trying to forge one out of the little metal cup things that tealight candles sit in... Didn't work, already frayed pretty bad. Defo gonna have to replace the cable when I get home. Just hope it survives a ride tomorrow....
Posted : 14/09/2016 9:29 pm
doublepost
Posted : 14/09/2016 9:30 pm
never thought of superglue.
i've taped one before. lasts longer than a ferrule generally does.
frayed ends are untidy but they aren't going to make it more likely to snap.
Posted : 14/09/2016 9:31 pm
You mean the cable end cap? A ferrule is the bit that goes over the cut end of the outer cable housing.
Posted : 14/09/2016 9:39 pm
What YoGrant said
Posted : 14/09/2016 9:43 pm
If it's the crimped endcap then I drop a bit of solder on mine, if you mean a cable stop then use a cut up rawlplug
Posted : 14/09/2016 10:00 pm
crimp on electrical connectors work well. Just cut the spade bit off
Posted : 14/09/2016 10:11 pm
Crimp on metal bit yes.
Posted : 14/09/2016 10:52 pm
 JAG
How about some Heat-Shrink tubing? Available from Maplins 8)
I've used metal Crimps but Heat Shrink tubing is much neater 🙂
Posted : 15/09/2016 8:58 am
