CAADX - Rack & ...
[Closed] CAADX - Rack & panniers? Numpty needs help
 stox
[#8009462]
Never had panniers on a bike before .. What do I need to know?
What do you recommend that doesn't end up costing me a fortune ? ..
Im thinking it'd make my commute a lot nicer without a bag on my back plus it's give me the option to ride to work on the days i got an urge to at the last minute.
It's a 2014 CAADX ... Will any rack fit? Will all panniers fit all racks?
Thanks
Posted : 20/08/2016 8:00 pm
Does the frame have the required eyelets? If yes most bolt on racks will fit depending on stuff like disc brake mounts you may need a disc variant of a rack. I use a standard topeak rack that happens to clear the disc on my boardman. Could put any bags on it bit the matching slide and lock bag works a treat on it.
Posted : 20/08/2016 8:06 pm
I commute with panniers and it makes a big difference. The extra weight takes a little getting used to but you'll be fine. They seem to be fairly universal but I could be wrong.
I've got an Avenir Touring rack with Avenir triple panniers, never had any issues with them. Paid about £70 a few years ago.
Posted : 20/08/2016 10:30 pm
 stox
Thanks. I'll check eyelets tomorrow but seen a few bikes (of the same year) on a Google search with panniers so assumed it has the fitments.
It is disk so that maybe something I need to be aware of when looking for a rack.
Posted : 20/08/2016 11:17 pm
My Alu Caadx has had mudguards on through standard eyelets, so yours should be fine.
Posted : 20/08/2016 11:32 pm
Yes youll be fine. My 2015 caadx is currently weighted down with all sorts of metalwork including a rack, it's got eyes in all the right places I'd imagine yours is pretty much identical.
It'd be worth trying some racks out for size in a real shop just to make sure they actually fit.
Posted : 21/08/2016 12:32 am
