Burgtec Pedals Help
[Closed] Burgtec Pedals Help
[#2358625]
Got a set of Penthouse pedals and Mk2 service kit, I'm a bit confused, and have a couple of questions (four in fact);
1. What's the difference between Mk1 and Mk2 pedals?
2. How do you know which you have?
3. Does anyone know where I can find assembly diagrams / parts list for these pedals?
4. What's the best method to get the old bushings out?
Any help much appreciated,
Cheers,
bigdonx
Posted : 11/01/2011 3:03 pm
I think Mk1's were a square platform, pins screwed in from top.
Mk2's are offset parallelogram shaped, pins mount from underside.
Bushings should push out with small flatnose screwdriver.
CRC does rebuild kits for £18
Posted : 11/01/2011 5:04 pm
What he said ----^
Posted : 11/01/2011 5:05 pm
Cheers guys, sounds like I have Mk2s then.
But the replacement bushings, from the CRC Mk2 kit, do not seem to be as "snug" on the axle shaft - quite a bit of daylight between. This puzzles/concerns me.
Maybe this is how they should be, but it would seem to allow much more twisting on the bearings than I would have thought healthy for them.
The old bushings - although now tight, seem to be of a much closer fit.
Any suggestions??
Posted : 11/01/2011 5:17 pm
Fit the bushes in the pedals first, before worrying about the tolerances. I've just rebuilt mine and although one of them is fine, the other does have some play but I think that's because the axel itself could be worn. I would check your axela with a vernier or micrometer.
Posted : 11/01/2011 5:33 pm
