Budget Handlebars
[Closed] Budget Handlebars
[#9628967]
Hi all,
Thinking of changing my bars to something with a bit more rise. My current Vitus bars only have 15mm rise and they look a bit odd when viewed from the side with alot of upsweep.
I've seen these Wake bars on Ebay: http://www.ebay.co.uk/itm/Mountain-Bike-Bicycle-Aluminum-Alloy-31-8-Clamp-30mm-Riser-740mm-Handlebar-PF/192287410640?hash=item2cc53909d0:g:kxEAAOSw9ENZnq2Q
They are made from 6061 Alloy. Does anyone have any experience of this Brand and their parts? Or would it be best to avoid them and go for a more well known brand like these: http://www.chainreactioncycles.com/funn-full-on-riser-bar/rp-prod91525
Don't really want to spend alot on something that is just a basic component.
Posted : 25/10/2017 5:38 pm
Got some funn full on's in 810mm with 7mm rise, more like flats really. Previously had some785mm 15mm in blue. Suit me fine, not sure what I would gain from spending any more. But go for what fits you.
Posted : 25/10/2017 5:42 pm
Do you have any spacers above your stem?
If so, could you rotate the bars so the upsweep is backsweep and raise the stem above the spacers?
Posted : 25/10/2017 6:31 pm
Sign up for bike bargains on Twitter, or go here. http://www.bikebargains.co.uk
Usually something will come up within a few days that you didn’t realise you needed! 😉
Posted : 25/10/2017 6:32 pm
Have a look at brand x bars on chainreacion. Only £16 but proper brand and backup. Choice of rise too.
Posted : 25/10/2017 8:30 pm
I have some 760mm low rise black Whyte bars in VGC - 7 rides old if you're interested 🙂
Posted : 25/10/2017 8:36 pm
No, I've already moved my stem above the spacers. Did think about using upsweep as backsweep but think it might look and feel a little odd.
Thanks, I already check that site regularly.
I looked at these but although it states the upsweep is only 5degrees the pictures seem to show quite a pronounced diagonal sweep from the centre to the ends like my current Vitus ones which look a bit odd on the bike.
Thanks but looking for medium rise 20-30mm. I think I might try those ebay ones for £10.
Posted : 26/10/2017 12:35 am
Hard Knuckleball bars were £34 yesterday at PX, Chewy version was more expensive.
Posted : 26/10/2017 7:02 am
Wanted ad in the classifieds got me a 30mm rise Renthal bar for £25 posted. I'd try there.
Posted : 26/10/2017 8:25 am
I just got some el guapo saloon bars from on-one for £13.
35mm clamp / 780mm width / 20mm rise and I think 9 degrees backsweep.
If you need 31.8mm clamp they're still £29.99 last time I looked.
Posted : 26/10/2017 9:50 am
Confused. You are wanting some budget bars to replace the oem bars because they look a bit odd from the side?
Bars should be chosen based on comfort and control surely.
Posted : 26/10/2017 11:15 am
I'd second what Nairnster says, but if you are going for new ones I tend not to trust unknown brands on ebay. Or known brands for that matter, given they could be fakes and non-snapping bars is my primary aim with these things (Saying that I've had bars from a well known quality brand snap after not that many miles on a road bike).
Posted : 26/10/2017 11:21 am
 mehr
As said above just get a funn full on bar, you're into a zero sum game when buying bars - Width(mm) 750/785/810 // Rise(mm) 15/30 // Backsweep (degrees) = 8 // Upsweep (degrees) = 5.5.
£22 from CRC
Posted : 26/10/2017 11:24 am
As I said in my OP wanted something with more rise too, wasn't just about the aesthetics.
Posted : 26/10/2017 11:28 am
