Brompton questions....
[Closed] Brompton questions...
Make absolutely sure you don't get any lube spray anywhere near the rear hub. It's waterproofed by packing it with grease...
Posted : 21/10/2013 12:01 pm
Fixing a puncture is easier with a 2-speed than it is with a 3- or 6-speed
Posted : 21/10/2013 12:05 pm
Posted : 21/10/2013 12:21 pm
Top tip - when you have to sort your first puncture or change a tyre, change the rubbish plastic rim strip that's put on in the factory for a nice proper cloth one - makes tyre removal, repalcement / seating waaaayyyy easier. The technical description for a Marathon Plus with the Brommie plastic strip is 'bastardtight'!
Posted : 22/10/2013 4:39 pm
Anyone any experience with the SA 8 speed conversion?
Worth the cash and extra weight or not?
(Currently have M6 but would like bigger gear spread and better changer...)
Posted : 22/10/2013 5:47 pm
Do test ride the 2 and 3 speed versions for comparison - I think you'll get what I and others are saying: The 2spd gears seem more useful than those on the 3spd. It's MUCH lighter and the gears can easily be swapped. If you want a 6 spd however, then go for it.
I can't agree with ransos - Feels like a BMX. Super nippy and great acceleration.
Posted : 22/10/2013 6:19 pm
I agree with this, I love how it rides. I'm 6'4", somehow it just works..
Posted : 22/10/2013 6:23 pm
Two years on an S3 here - 85 miles a week year round.
Marathons are good - got my first puncture the other day because the sidewall wore out just before the tread did.
Front luggage block and S bag is worth every penny.
One thing- I did manage to shatter the pawls in the SA hub withinna week or two. Advised to start in easiest gear rather than pushing the big meat..
Posted : 22/10/2013 6:40 pm
AndyMain - I would be interested in your Brompton as mine was stolen, email in profile if still available.
Posted : 23/10/2013 11:19 am
Just finished an Alfine 11-speed disc kit:
Now to start building Rohloff disc Bromptons - got three to build this week...
Posted : 23/10/2013 11:21 am
Katie's Alfine 11 has now started pissing oil from the disc side as well as the drive side 🙁 Every Alfine 11 I've seen seems to leak oil like crazy.
Posted : 23/10/2013 12:25 pm
Which is why I'm not sure I want to make any more of these - someone asked, and provided the hub, so I said I'd give it a go 😉
Posted : 23/10/2013 12:34 pm
Ben, how does the range of the 8 speed compare to the 6 speed BWR?
I find that I'm only using the higher 4 and ideally would like a closer set of ratios......
Posted : 23/10/2013 12:45 pm
It's a bit wider - 325% - from 29" to 94" with the 33t chainset I usually use.
Posted : 23/10/2013 12:47 pm
thanks for that....I'll go and have a Think....may well give you a call...
Posted : 23/10/2013 12:51 pm
It's flexy and heavy.
Posted : 23/10/2013 1:10 pm
I'm constantly puzzled about these remarks about flexy. I'm pretty sure the stock Stronglight cranks are as flexy as heel, and I'm going to swap them for some old HT 105s soon, but the rest of the frame seems pretty beefy to me. Where are the flexy people seeing the flex, may I ask?
On the Alfine conversion: I've got a Nexus 8 hub on my Specialized Tricross at the moment that is cut down to 120mm OLD. I'm quite tempted to build it up for the Brompton at some point - although it seems overkill for my 6.5 miles each way commute. That might resolve the Alfine oil problem - although it'd be no help on the disc side of things.
Posted : 23/10/2013 1:21 pm
The bars and stem can be pretty flexy, especially the M and P bars. The Alfine 8-speed seems a lot more reliable than the 11-speed.
Posted : 23/10/2013 1:46 pm
Page 2 / 2
