Broken tooth on Sra...
[Closed] Broken tooth on Sram xo eagle cassette - biggest ring
[#11411709]
There’s nothing for it - I need to replace the whole cassette right?
Posted : 04/10/2020 10:17 am
I lost one off a gx, the 50 tooth alloy one. I'm just glad of the weight saving 😉
Posted : 04/10/2020 10:25 am
Smooth the edges off and carry on. Think how "reduced" the teeth used to be on 46t chain rings.
Posted : 04/10/2020 10:28 am
Just use the other 11 gears.
Posted : 04/10/2020 10:29 am
If it's still working ok just carry on using it.
Posted : 04/10/2020 1:30 pm
You'll be fine, the chain will engage with more than enough teeth to not cause an issue, ignore the lost tooth until more fall off, think my GX 12 speed lost 3 teeth in the big ring after 1 months usage, still worked though as they were far enough apart.
Posted : 04/10/2020 3:09 pm
Cheers!
Posted : 04/10/2020 6:31 pm
