Brken Brake lever b...
[Closed] Brken Brake lever bolts
[#4051064]
I was adjusting my brake levers Formula R1 and managed to snap one of the clamp bolts. Fortunately I was swapping my lock n grips at the same time so salvaged a bolt from the old grips though it appears to be a few millimetres shorter.
The question is the Formula R1 clamp bolts are known to be made from toffee, should I get a bolt set or should I get some titanium bolts. It all seems to hanging together perfectly well even after a recent crash where I rotated the brake lever around the handlebars.
Just after advise.
Posted : 09/06/2012 12:04 pm
You should save yourself a small fortune. Find a local engineers/fixings & fasteners supplier, and pick up some stainless ones for around 20p each.
Posted : 09/06/2012 6:35 pm
