I'm going to stick a CRC order in, but I've never managed to get the BC discount code thing working. Am I doing something wrong, what's the knack?
Login to your CRC account before attempting to apply your BC discount code. If you put the code in then get asked to login to your account you lose the code
You have to spend £100 or more. You can't use it on clearance items. Put the code into the box and add before selecting check out.
If you lose your code you can call and they will help you .
You can’t use it on clearance items.
You sure? I used it on some very reduced kit the other day
Boom! Sorted, cheers all.
Me too, I've always got my 10% off everything. Can't apply two codes though so can't have say an extra tenner of £x of clearance items AND 10% BC discount, it's one or the other.
also, copy and paste from british cycling dashboard to get the exact code
you dont lose your code permanently if you dont log in first, just get in touch with crc customer service
Does it make any difference what level membership you have to what discount you get? I was hoping to gret away with 'Fan' as I don't really need any of the other stuff
Fan is fine that's what I am. All discounts work for me
