I want to get some cable guides brazed on to a (steel) 4X frame for a front mech. Probably under the top tube, to go with the rear guides, unless someone has a better idea.
Will it take a lot of the paint away? I don't really want to get the whole frame resprayed, is it OK just to touch it up with hammerite?
Has anyone had this done? Is there a better/easier way using bolt on guides or something?
ta,
thebunk
You could always get some jagwire stick on cable guides and they come with the plastic clips:
http://www.ecrater.co.uk/p/9735804/2-x-jagwire-alloy-stick-on-housing-cable
http://www.bicyclehero.com/gb/jagwire-alloy-stick-on-cable-guide-silver-dca053.html
They look good. I guess I still need a cable stop though?
Have a look [url= http://www.sjscycles.co.uk/down-tube-stops-fittings-dept668_pg1/ ]here[/url] for that ... more stops than you can shake a stick at. (Maybe ... )
Coo, ta! Who knew this stuff existed?! Guess it's worth trying before getting it welded...
