Brand x dropper cab...
[Closed] Brand x dropper cable clamp size?
[#11278160]
Hello.
I've found a brand x dropper to replace my temptemental reverb but I need the cable clamp. Does anyone have a good source for them or alternatively the size so I can bought something up please.
Thanks
Posted : 02/07/2020 4:25 pm
Do you mean the bit that the cable goes through at the lever end?
I’ve got a freshly delivered today Ascend II sitting in the garage. If you want I’ll measure up before I fit it after I’ve finished work.
Posted : 02/07/2020 5:12 pm
Slam69 have KS ones. if you mean the barrel n grub screw thingamajig.
Posted : 02/07/2020 7:35 pm
They're the Badgers! Seem like small diameter of someone could measure that would be cool thanks
Posted : 03/07/2020 1:34 pm
I'll have a look at mine- though I don't have a micrometer so will be judging by eye vs a rule.
Posted : 03/07/2020 2:23 pm
Hi, it’s 9mm long and 6mm In diameter. This is the clamp I’m referring to! The grub screw goes in one end of the clamp.
Posted : 03/07/2020 4:26 pm
Top work, thank you
Posted : 03/07/2020 7:20 pm
No worries, I even wore my glasses to get it as accurate as possible.
Posted : 03/07/2020 9:06 pm
