Brand X ascend drop...
[Closed] Brand X ascend dropper seal
[#11926102]
My seal on my dropper has split and no one seems to have a service kit in the UK available at present. Does anyone know if I could get a seal that would fit anywhere else ?
Posted : 17/06/2021 11:21 pm
Have you searched for a kit for the RSP droppers etc, they share *some* parts I believe? Other brands too.
Posted : 17/06/2021 11:24 pm
What model? The one up v1 seal kits fit the brand x xl ascend. Also think shimano koryak seals fit
Posted : 17/06/2021 11:50 pm
It's a couple of years old brand X ascend 160mm internal cable post
Posted : 18/06/2021 10:32 am
Try here - https://www.evocycles.co.uk/brand-x-ascend-maintenance-kit/mpn:806234_z/
Posted : 18/06/2021 12:38 pm
Tried that site but they don't have any stock, I wondered if it's a standard seal I could pick up somewhere else ?
Posted : 18/06/2021 1:57 pm
Do you mean the main stanchion seal? I was under the impression that they were all the same size.
Posted : 18/06/2021 2:11 pm
Where's the valve to add air on these?
Posted : 18/06/2021 2:26 pm
Schrader valve under the seat on mine, yeah I might just order an external service kit and see if the seal fits I would guess they would all be the same, we will see
Posted : 18/06/2021 5:08 pm
The wiper seals are the same on all brandX models. Ebay for kits
Posted : 18/06/2021 10:21 pm
Mine works perfectly fine but sounds a little dry like it needs some lube to make it smooth and silent - lube or service time?
Posted : 20/06/2021 10:47 pm
https://www.amazon.co.uk/Pro-yprsp0194-Seatpost-Together-Multi-Colour/dp/B01NBNJ2JH
I used a Pro Koryak kit for mine. Stealth Ascend XL 170mm.
I think the Ascend 2 users the same kit as the One up V2.1
Posted : 20/06/2021 11:44 pm
And not all Ascend posts have a valve. I've am older 150mm and a 170mm with a valve, and a newer old 150mm with no valve.
Posted : 20/06/2021 11:47 pm
