Brand new reverb st...
[Closed] Brand new reverb stuck down
[#10974793]
Not mine - friends wife’s
Bought and stored in the down position - now won’t extend. How do we sort it before she finds out?
Posted : 22/12/2019 10:30 pm
Needs air? Valve at top.
Posted : 22/12/2019 10:34 pm
Try that first, cheers
Posted : 22/12/2019 10:35 pm
Is the speed adjuster full fast? If it is give it a bleed and see if you can pop it up. If you can then once its up do a full bleed again.
Posted : 22/12/2019 10:38 pm
Check the seat post clamp isn't over tightened. Check air pressure is correct and bleed the hydraulic line.
Posted : 22/12/2019 11:13 pm
Most likely needs a bleed - it should have cane with the kit and some fluid.
Posted : 22/12/2019 11:43 pm
Check air, should be at 250psi
Posted : 23/12/2019 12:08 am
 Gunz
Sell the bike to a shorter person.
Posted : 23/12/2019 1:48 am
I'd be very surprised if one of the above suggestions doesn't fix it. Check air first, then put adjuster to full slow before bleeding.
Posted : 23/12/2019 10:47 am
As above, in order of pressure, clamp torque, bleed. One of mine when new lost a bit of air but since then has never lost any at all. It's now all but totally ****ed from general abuse, so no idea why it lost pressure then and never again.
Posted : 23/12/2019 11:33 am
Hopefully the above will sort it... but I'm struggling here on someone buying a reverb for someone they love. (and failing that.. being the person has to fix it every time it throws it's toys out of the pram because its cold or damp or wrong type of leaves on the track?)
Posted : 23/12/2019 1:19 pm
If you check the pressure with the post fully compressed then make sure you check it again when its fully extended as thats when the 250psi pressure should be achieved.
