Brakes using minera...
[Closed] Brakes using mineral oil
[#3604945]
What can you use to lube the pistons? the seals are different from Dot fluid ones are they not.
I have only worked on dot fluid brakes before and use red rubber grease or dot fluid to lube pistons. what do you use on mineral oil brakes? I don't have any mineral oil to hand. anything else compatible with the seals? Silicone spray oil?
Posted : 24/01/2012 10:59 pm
Veggie oil?
Posted : 24/01/2012 11:04 pm
Lube Pistons? What is this black magic you speak of?
Posted : 24/01/2012 11:06 pm
 JAG
Simple really - any mineral oil based lubricant.
That's traditional oils and greases as available from any motor factor etc...
 AD
Silicone oil/grease will also be fine if you don't have any mineral oil to hand.
Posted : 24/01/2012 11:08 pm
Its all about preventative maintenance Druidh 🙂
Actually its as et of tektro brakes I got for a pal and the pistons are sticking in the seals a bit as they have not been used - lever travel is longer than it might be as a result.
Jag - so any ordinary oil will do?
Posted : 24/01/2012 11:09 pm
Ta sorted. Need bleeding as well tho 🙁 so I will have to get some mineral oil
Posted : 25/01/2012 12:13 am
