Brakes not working
[Closed] Brakes not working
[#5296316]
I just come back off holiday and my bikes been upside down for a while, the front brake now comes straight to the bar. Is there any tip for sorting this that doesn't require bleeding?
Posted : 01/07/2013 7:30 pm
Try zip tie round brake lever or elastic band.... Leave overnight and let lever off slowly. Helps to periodically tap hose and caliper. This may work.... Also make sure reservoir full of fluid!
Posted : 01/07/2013 7:36 pm
Turn it the right way up! Better still store it the right way up if you can.
Leave it (right way up) for a bit and then pump the leavers. It they should get better but you may still need a bleed. Avids by any chance?
Shimano xt's
Posted : 01/07/2013 7:37 pm
The holding the brake lever trick is good for a short term fix but just get them bled; it's the only way to fix it properly.
Oh may also help to advance pads a bit.... Pop off caliper and give the lever a full pump. You should see pistons move out and return a little further in than before. This should stiffen lever up a bit.... What brakes?
May need a full bleed but worth a try!
Posted : 01/07/2013 7:38 pm
I was hoping to get a quick fix until my bleed kit arrives I think
Posted : 01/07/2013 7:41 pm
Get on your bike.... Once the air is out its out..... Unless you have a leak somewhere! The lever to bar trick has worked many many times for loads of people.... I am convinced people bleed at any opportunity.... You really don't need to if you understand what's happening! It's usually unessesary bleeding that messes things up.
Good luck
Posted : 01/07/2013 7:42 pm
