Brakes - M965 and M...
[Closed] Brakes - M965 and M675 compatibility
[#5458671]
A quick question, is the SLX M675 caliper compatable with the 'side banjo' connectors used on XTR M965 calipers? I have braided hoses at the moment and it would be nice if the M675 calipers fitted straight on with no fiddling.
Also, are M675 calipers compatible with deore LX levers? mine are older LX levers so would they provide enough 'power' to fully operate the m675 caliper?
cheers
Rich
Posted : 27/08/2013 9:47 am
The banjo bolt on the M675 is different to the M965 one but the banjo on the hose is fine, you just need to buy the longer bolts.
Posted : 27/08/2013 10:33 am
