Brakes howling afte...
[Closed] Brakes howling after bleed
[#5610313]
As above, I guess I must have got a little oil on the pads/discs. Would blasting them with a steamer help?
Posted : 17/10/2013 9:25 am
Dunno about the pads but one of those hand held steam cleaners works a treat on rotors..
Posted : 17/10/2013 9:27 am
If you've got fluid on the pads, they're fubarred. Replace. Clean discs with IPA or propietory brake disc cleaner beforehand.
Posted : 17/10/2013 10:46 am
Depends on how much... you might be able to get away with sanding the pads down and cleaning the rotors with IPA
Posted : 17/10/2013 11:48 am
Schoolboy error!
Posted : 17/10/2013 11:52 am
I've never managed to rescue any contaminated pads. I've tried all the usual suggestions. It's happened an embarrassing 5 times and each time the only way to cure it properly has been new pads. The continuing expense of being clumsy 🙁
Posted : 17/10/2013 11:53 am
Actually, having said that - no-one's actually asked if your brakes work properly, despite the howling?
Mine squeal like a pig just after I wash the bike and degrease everything, but they work just peachy.
Posted : 17/10/2013 12:11 pm
Did you take the calliper off (i.e. calliper and disc now misaligned)? Could cause one pad to touch the rotor before the other...
Posted : 17/10/2013 12:17 pm
aaaawwwwwwoooooooooooooooooooo!
Posted : 17/10/2013 12:20 pm
I see what you did there, brakes. 😆
Posted : 17/10/2013 12:27 pm
Wash pads in soapy water then put em on a hot hob
Burn off the oil
Quick sand and put em back on - done this once before and it worked fine.
Posted : 17/10/2013 1:50 pm
