Brake rotor bolts.....
[Closed] Brake rotor bolts....which ones?
[#1109548]
Hi, looking for some disc rotor bolts (M5x10mm), should they be high tensile (like the self coloured black ones) or could they be stainless steel?.
Which is stronger as i am under the impression that stainless is not as strong as high tensile, am i wrong and being too concerned?
Posted : 07/12/2009 8:28 pm
I use mudguard fixing bolts, fine after 6 year's use - including some extreme...braking 😛
Posted : 07/12/2009 8:29 pm
stainless is not as strong as high tensile and shouldn't be used in load bearing applications.
although on a disc rotor, its really not going to make much difference i think, considering i have ti ones and only 3 in each rotor :S
Posted : 07/12/2009 8:33 pm
