brake pads cyclocro...
[Closed] brake pads cyclocross help
[#3622705]
ok I've got some frogglegs with trp brakes:http: http://www.winstanleysbikes.co.uk/product/23115/TRP_Inplace_Adjust_Cyclocross_Alloy_Pads_and_CNC_Holders
after a few rides the pads are right down.
I believe people rave about kool stop salmon pads.
heres the (stupid) question...will new pads simply screw into the brake "shoes" or will I need the complete thing again.
Posted : 30/01/2012 12:02 pm
You unscrew the small screw and the rubber insert slides out. So you only need to buy the rubber insert.
Posted : 30/01/2012 12:22 pm
are the inserts all the same size? or will I need to keep to trp ones?
(looks like every brand is different sizes)??
Posted : 30/01/2012 12:25 pm
Not sure but mine are Tektro and I've run Avid and BBB pads which were the same size. Sorry can't be more helpful.
Posted : 30/01/2012 4:59 pm
bump
Posted : 30/01/2012 5:12 pm
