Want to stock up on some pads. Do 105 and Tiagra use the same pads?
Hydraulic discs.
Yes
Woohoo!
Cheers!
Yep, and Ultegra/XTR/DuraAce as well!
There is the Shimano compatibility chart although it only shows the latest iteration of brake pads. The numbers (03,04,05) are just the generation of pad material so a G03A will fit the same as a G05A but the latter is supposedly improved and lasts longer.
https://productinfo.shimano.com/#/com?cid=C-460&acid=C-653
The Gorilla website, as an example, also shows compatibility of their equivalents.
This has been very useful for me as I was scratching my head about which pads to buy for my Tiagra.
One question though, what do the different initial letters mean? Some have a KO prefix and some LO. Is it basically the same pad but with the fin, or is it something else?
Yep, I think so. K = no fin, L = with fin. As above, the number is the generation, and the letter at the end is the material.
G and J are the not finned/finned equivalents for non-flat-mount brakes.
K and G look quite similar, but are not interchangeable. Likewise L and J.
