brake mounts questi...
[Closed] brake mounts question
[#3493735]
Hi,
I'm building up a new bike, and currently I have a rear brake but with a 203mm rotor. If I got a 180mm for the front and swapped the rotors over I would need new mount adaptors for both brakes wouldn't I? Also can you use a different brand of mount to the brake that you have?
cheers
Posted : 26/12/2011 2:16 pm
Hope B mount (or equivalent from another maker) shows as fitting F203 / R183 if you can find a 183 rotor.
Posted : 26/12/2011 2:36 pm
