Brake mount help
[Closed] Brake mount help
[#5077164]
Hi guys,
I bought a new set of reba forks and at the time some new shimano SLX discs with a 180 mm rotor for the front.
I got them all from Merlin, I asked the guy what adapters I needed and they have sent through an IS 180 mm which I can't see that I need it because it looks like it is post mount on the forks. Can anybody confirm this? Also I can't get fit in the 180 rotor, I guess it needs some sort of spacer to move the caliper back a tad, is this right?
thanks in advance.
Chris
Posted : 17/04/2013 8:55 pm
AFAIK forks come ready for 160 and frames ready for 140 so you need a 160/180 pm/pm adapter - but someone will be along soon to agree or correct me !
Posted : 17/04/2013 9:00 pm
What are AKAIK forks?
Posted : 17/04/2013 9:17 pm
I think the post mounts are both 160mm without mounts. Get a shimano 180mm post to post adapter. Will work on the back for 180mm disc as well if you choose to run it back there.
Just done this for a mate on his new FF29'er
Posted : 17/04/2013 9:18 pm
[url= http://www.acronymfinder.com/AFAIK.html ]AFAIK[/url]
Posted : 17/04/2013 9:19 pm
