Brake mount confusi...
[Closed] Brake mount confusion: what am I doing wrong?
[#10813493]
X-Fusion Slant fork with 180mm brake post mounts. Wheel with 180mm rotors. Deore caliper. Should work, but the rotor and the pads are barely aligned.
[url= https://live.staticflickr.com/65535/48736065753_409c6922cd_c.jp g" target="_blank">https://live.staticflickr.com/65535/48736065753_409c6922cd_c.jp g"/> [/img][/url]
Any ideas what I'm doing wrong? So far there's been a slew of failures trying to get my kid's bike built (wrong bottom bracket shell size, no rotors the right size, calipers leaking) so this isn't my day so far. 🙁
Posted : 15/09/2019 1:15 pm
Are you 100% sure it's a 180mm rotor you have on there?
Posted : 15/09/2019 1:24 pm
I was going to say the same as jabbi - that looks like a 160...
Posted : 15/09/2019 1:25 pm
Think we need to see where it says the rotor is a 180....
Posted : 15/09/2019 1:27 pm
Convenient 160mm rotor in front of the 180mm.
[url= https://live.staticflickr.com/65535/48736493441_dd0cc387d5_c.jp g" target="_blank">https://live.staticflickr.com/65535/48736493441_dd0cc387d5_c.jp g"/> [/img][/url]
Posted : 15/09/2019 1:38 pm
 PJay
What year is the Slant? There's some suggestion [url= https://singletrackworld.com/forum/topic/x-fusion-slant-rotor-compatibility/ ]here[/url] that the Slant takes a 203mm rotor; if that's the case I don't know whether a PM203-PM180 adapter is available.
X-Fusion's [url= https://www.xfusionshox.com/products_detail/70.htm ]Slant page[/url] states:
Max Rotor Size:180mm/203mm (XF adaptor only)
but it's not clear which rotor size needs an adapter or which it takes without an adapter.
Posted : 15/09/2019 1:45 pm
Quite old, it’s a bit battered and from eBay.
Posted : 15/09/2019 1:47 pm
Are you 100% sure it’s a 180mm rotor you have on there?
Think we need to see where it says the rotor is a 180….
Looks like 170
Posted : 15/09/2019 1:48 pm
Needs a larger rotor
Looks like mine did when I fitted an adapter when one one was needed on my sweeps. Try a different rotor , just to check the sizing.
Posted : 15/09/2019 2:05 pm
Very early slants seem to have come with a bigger rotor mount.
https://forum.bikeradar.com/viewtopic.php?t=13015931
Posted : 15/09/2019 11:08 pm
So my 10 year old son is going to have a bigger front rotor than me! 🙂
Posted : 16/09/2019 12:45 am
