brake levers to wor...
[Closed] brake levers to work with canti's?
 ton
[#2228422]
got some new avid shorty canti's coming for my lht
which levers work with canti's................cos i forgot.... 😐
Posted : 26/11/2010 11:09 pm
On-One used to have some Dia-Compes I fink?
The number 959 comes to mind, but don't quote me on that.
Posted : 26/11/2010 11:22 pm
 ton
oldgit sorry.............i should have said, flat bar levers....doh
Posted : 26/11/2010 11:24 pm
Yeah I know that's what you meant. I had to buy some for a 92 Kona I put together.
Anyway had a look and they ain't still there. Though I'm pretty sure it'll be Dia-Compes that'll be the easiest to get hold of.
Posted : 26/11/2010 11:26 pm
 ton
ta mate.
Posted : 26/11/2010 11:27 pm
Go for some Avid Speed dial's.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=22387 ]CRC[/url]
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=54469 ]Or these[/url]
I used them with BB7's and they worked great.
Posted : 26/11/2010 11:38 pm
 ton
ta mate...........sorted
Posted : 26/11/2010 11:59 pm
I got some used once Avid levers if you are interested.
Posted : 27/11/2010 12:23 am
What did you get?
I thought levers for Vs didn't pull cantis?
Posted : 27/11/2010 2:25 pm
yeah i didnt think v's pulled cantis ? i hope they do lol i could do with ditching my crap v's and putting cantis on
Posted : 27/11/2010 4:05 pm
 ton
i think it is the other way round.
canti levers do not pull enough cable to work vee's.
vee levers pull more cable so shoiuld work.
i had some avid sl's which i will try.
Posted : 27/11/2010 4:08 pm
oh i hope so 😉
Posted : 27/11/2010 4:10 pm
You are meant to use levers designed for the brake. BMX levers would work as they are designed for U brakes. The one thing I'm not sure of though, is whether the speed dial thing on Avid levers has enough adjust-ability to make it compatible with both types of brake.
Posted : 27/11/2010 4:56 pm
You should use canti-specific levers. Shimano do some (Nexave) ones IIRC.
Posted : 27/11/2010 4:59 pm
Ton, Shimano do a couple of levers designed for caliper and canti brakes. BL-R550 (£19.99) and BL-R770 (£29.99). Both in stock at madison so your local shop should be able to get them easily for you.
Posted : 27/11/2010 5:14 pm
Anything canti doesn't work with anything v. Best lever ever for canti brakes was the diacompe pc-5 and pc-8. Worth tracking down if you can.
Posted : 27/11/2010 5:43 pm
 ton
now ordered some of the shimano r550 ones................cos you lot made me doubt myself........ 😉
Posted : 27/11/2010 6:07 pm
