Brake hose compatib...
[Closed] Brake hose compatibility Hope Avid
[#4088521]
Does anybody know whether Hope brake hose is compatible with Avid Juicy brakes? I want to fit out a tandem and have sourced cheap Hope hose off the reel which is standard 5mm but can't find any relevant info.
Thanks
Posted : 21/06/2012 8:16 am
Anybody know?
Posted : 21/06/2012 6:09 pm
The hose might work, the stainless certainly will but the fittings are different. Why not use goodridge kit for a tandem?
Posted : 21/06/2012 6:32 pm
yups.
hose is... hose. inner/outer diameter, structural stiffness and uv stability of materials are the real considerations.
Fittings are a different matter and may well even vary within brand.
Based on your original post of Hope hose off the reel you should be fine; just make sure you buy the right fittings for your brakes.
[url= http://superstar.tibolts.co.uk/product_info.php?cPath=68&products_id=431 ]Superstar may be worth a look[/url]
Posted : 21/06/2012 6:45 pm
Thanks for replies.I have the Avid fittings so just wanted to know whether there may be problems with hose compatibility.
Steve
Posted : 21/06/2012 8:36 pm
Internal diameter could be an issue.
Posted : 21/06/2012 8:39 pm
Does anybody know internal diameter for Hope and Avid hose?
Posted : 22/06/2012 8:23 pm
