Just got the bike out of the shed to brush the mud off from the STW Swinley mudfest a few weeks ago and rear brake lever (recently come back from Hope for full service) pulled right back to the bar. It was better when I pumped it but when left for a few secs it pulled back to the bar.
Is this just from sitting around in a cold shed unused or could I have a leak somewhere? Can't believe it needs bleeding only 3 months after a full service...
ta
sounds ****ed, checked fluid levels ?, check seals around pistons for leaks ? hose damaged ?
check pads as well as in are they still there / worn away
Have you had the bike upside down? sounds like air in the system to me
Bleeding them is dead easy
Bleed the brake.
Just take the top cap off the lever (master cylinder), half turn on teh blled nipple on the caliper and pump the lever. catch the fliud to stop it going on the pads. keep pumping the lever a few times.
Then top up the master cylinder with 5 dot fluid and pump the lever some more. Tighten up the bleed nipple top up with fliud and put the cap back on.
if thats not it then something in the master cylinder is knackered or the piston in teh caliper. thats if nothing is leaking.
Do not use DOT5 fluid, you need DOT 4 or 5.1 or even 3
5 is different stuff altogether
Worn pads? I'd check that first because Swinley eats brakes in the wet. If the pads are low, brakes can get spongy.
Could also be sticking pistons,funnily enough, often caused by leaving the caliper sitting in mud for 3 weeks.
