Brake discs- interc...
[Closed] Brake discs- interchangeable?
[#5763716]
As the title really. Can you run avids with shimano? Or any disc with any brake? What the the disadvantages? Looking to run some avid discs with new shimano slx
Posted : 10/12/2013 9:09 pm
yes you can
Posted : 10/12/2013 9:24 pm
As long as the braking surfaces are the same size there shouldn't be a problem. I run Avid G2 203mm rotors with my Hope mono M4 brakes witout issues.
Posted : 10/12/2013 9:26 pm
I run Magura discs with Shimano brakes, for the simple reason that I prefer the look of the wavy Maguras rather than the boring circular Shimanos
Posted : 10/12/2013 9:32 pm
[i]Fairly[/i]. Some floaters are pretty bulky, so frinstance my Hopes didn't work with my old Shimano brakes unless they were perfectly centred. And braking surfaces do seem to vary a bit though I've never worked out a hard and fast rule for that- Formula seem fairly narrow, Shimano pretty wide.
Posted : 10/12/2013 9:38 pm
Most aftermarket rotors don't come in different sizes(width) do they? So must be much the same
Posted : 10/12/2013 10:14 pm
I' ve run shimano, Tektro, Hayes, Hope and Ashima rotors in a random mix of Hayes, Hope and shimano calipers without issue. I have never tried floating rotors but for fixed I have yet to experience any problems other than swapping part worn rotors from a shallow pad (eg M4) to a deeper pad that contacts the rotor further in towards the hub (eg Deore).
Posted : 11/12/2013 12:00 am
