Brake disc play rou...
[Closed] Brake disc play round hub.
[#7573292]
Why would a brake disc rotate round the hub a few millimetres then reengage? Brand new bike, both front and rear.
Supplier will repair but I' m just so impatient to know!
Hub (Front) Formula CL51
Hub (Rear) Shimano FH-RM35 Disc
Posted : 12/01/2016 7:02 am
Loose brake mounts?
Posted : 12/01/2016 7:06 am
centerlock hubs?
Worn splines, not in tolerance, ham fisted fitting?
Posted : 12/01/2016 7:08 am
Yes mike, that red hub looks similar.
Are they easily tightened or is a special tool job?
Posted : 12/01/2016 7:53 am
If it is centre lock then there's nothing you can do about it now. Worn splines means the hub is for the bin
Posted : 12/01/2016 8:07 am
That's the beauty of Centerlock - nothing to worry about or to fix. There will always be some play in the splines - you can tighten the nut to make it "disappear", but deep down you will always know there is play.
Posted : 12/01/2016 8:09 am
Is it actually the disc moving in relation to the hub, or just the pads moving slightly in the carrier?
Posted : 12/01/2016 10:07 am
legend - Member
On a brand new bike though?
Is the lockring tightened up OP?
Posted : 12/01/2016 10:34 am
