Brake caliper swap....
[Closed] Brake caliper swap...what bolt do I need
[#11170929]
I'm just in the middle of swapping my 2 pot m8000 xt caliper with the 4 pot m8020 one however the bolt to connect the hose is too long - what do I need?
Posted : 02/05/2020 2:59 pm
Assuming it's the same as a Saint or Zee caliper this is what we had to use to convert XT 2 pot to Saints
https://www.sjscycles.co.uk/brakes/shimano-deore-brm555-banjo-bolt-oring-y8h098010/
Posted : 02/05/2020 3:59 pm
Yep, good old SJS Cycles! Thanks Tracey. Have ordered one of those.
Posted : 02/05/2020 4:08 pm
 PJay
I bought a couple of SLX M7100 callipers a while ago and had some BH90 hose to use. The newer Shimano callipers have the banjo on the righthand side and need a bolt about 1/3 of the length of the old style bolt supplied with the BH90.
Fortunately the correct banjo bolt was supplied with the calliper; I'd assumed that this was always the case, but perhaps not.
Posted : 02/05/2020 5:16 pm
I triple checked the box that the caliper came in but no bolt to be found.
Posted : 02/05/2020 6:50 pm
None of ours came with banjos
Posted : 02/05/2020 7:28 pm
