Brake Adaptors
[Closed] Brake Adaptors
[#11120492]
I’m building up a cheap first ride for my nephew. Mainly using parts bin and donations. I’m hoping I can get the old brakes/fork/frame working together. Now I understand about different mounting systems for the brakes but I don’t seem to be able to find what I think I may need.
Frame - Commencal COMBI Disc
Brakes - Juicy 3
Fork - Manitou Splice Elite
The discs are 160mm so I thought the brakes would fit without adaptors but it seems not. Any ideas what I need. All are post mountings (frame comes with adaptor). The callipers are close to fitting but not quite. Any assistance appreciated.
Posted : 03/04/2020 1:53 am
Are you missing the tri-align washers?
Posted : 03/04/2020 1:57 am
 poah
What SR says above. Without those washers the bolts are too long for the mount (left side).
Posted : 03/04/2020 4:39 am
If its very close to fitting you may just find its an inconsistency between manufacturers. Sometimes solved with an extra washer on the mount.
Posted : 03/04/2020 8:06 am
+1 for tri align washers
Posted : 03/04/2020 8:19 am
Right, cheers, yeah they look like they would do the job. I don't even have bolts at the moment so I will pick up a kit. Something like this:
https://www.tredz.co.uk/.Avid-Avid-Caliper-Mounting-Hardware-Inc-Caliper-Mounting-Bolts-Washers-CPS-Standard_67320.htm?sku=201894&utm_source=google&utm_medium=cpc&utm_campaign=google_shopping&gclid=EAIaIQobChMIo7qv3MzL6AIVQ0PTCh0xoANfEAQYASABEgLr9PD_BwE
I presume?
